I have a real step constant serving as the source for a linear valve in Modelica. I would like to control this input.
I tried redefining the parameter k=k: "parameter Real k = 0.5;" --> works fine, gives a result!
Then if I redefine as "parameter Real k;" and try defining "k = 0.5;" under equations, I get the error that there are one too many equations. Okay...kind of makes sense as I did add one but I only defined k once.
My goal was to define k in equations so that I could set up a controller to stabilize flow. Should I be able to do this? If not, is there another method I should be trying?
Thanks!
