Hi, I want to cosimulate E+ in Dymola, basically I want to model the energy system (GSHP PV etc...) in Dymola and use the FMU to simulate the flats. To do this I need to send the temperature and the mass flow of the water coming from the GSHP in Dymola to the FMU as an input, in other words the temperature of water in node after the HP in E+ must be defined with Dymola. I'm trying to use the actuator but I can only modify the setpoint, what I have to do to modify a variable in E+ with a signal from Dymola?
Hope that someone can help.
Regards Giorgio
