Methods I thought:
1- EMS Actuator component type: airflow network window/door opening EMS actuator component control type: venting opening factor EMS Sensor: Surface Outside Face Temperature Airflow network: multi zone: surface: set max opening factor
2- EMS actuator components type: surface EMS actuator component control type: construction state Fenestration surface: detailed: subdivide the fenestration surfaces into smaller sections and control construction state actuator in EMS
Which one is better, or is there any other more suitable way?
Thank youu!
