window-to-wall ratio (wwr)
Is there a way to manually input the window-to-wall ratio calculations in Detailed Mode? Currently, I have to enter the percentages for each level for each orientation the Wizard Mode. This becomes a time consuming task for high rise buildings. Thank you.
