How to have Radiance Daylighting measure compatible with OpenStudio 1.4.0?
I need to use ResultsViewer, because I would like to have illuminance map like the image below:
I use OpenStudio 1.4.0, SketchUp2013. But unfortunately, when I try to download Radiance Daylighting measure, it says that: "This measure require a newer version of OpenStudio"
But newer version doesn't have ResultsViewer, would you please let me know how can I access to the file of this measure which is compatible with OS 1.4? (I can install it manually)
