Difference in results
Hi everyone, I have noticed a difference between the results of the “district heating meter” When i run the model in 2 modes. First, I run the model in open studio,and check the energy plus results in the open studio report tab Second,I export an idf file , defining the proper meter and run the simulation using the EP lunch. The first one is higher (about 4000 kwh more) and I don’t know why...and which one is realistic!!!! Thanks in advance if you help me understand this problem.
Difference in E+ results
Hi everyone, I have noticed a difference between the results of the “district heating meter” When i run the model in 2 modes. modes.
First, I run the model in open studio,and check the energy plus results in the open studio report tab tab.
Second,I export an idf file , defining the proper meter and run the simulation using the EP lunch. lunch.
First, I run the model in open studio,and check the energy plus results in the open studio report tab.
