I am trying to model 12.7 cm wide vertical blinds using WindowMaterial:Blind:EquivalentLayer. When I do so I get the following errors:
* Severe * Out of range value Numeric Field#1 (Slat Width), value=0.12700, range={>0 and <=0.025}, in WINDOWMATERIAL:BLIND:EQUIVALENTLAYER=WMTEUQL_BLND_KINDV_RF80_T02_A18_RB45 * Severe * Out of range value Numeric Field#2 (Slat Separation), value=0.12700, range={>0 and <=0.025}, in WINDOWMATERIAL:BLIND:EQUIVALENTLAYER=WMTEUQL_BLND_KINDV_RF80_T02_A18
The input should be in meters. It seems a bit strange that the slat width would be limited to a maximum of 2.5 cm. Wider products are quite common and for vertical blind a slat width as small as 2.5 cm doesn't exist. The input output reference also state that 2.54 cm should be the default value.
I am using EP 8.5. I have also tried updating to 9.0 but this still gave the same error. My WindowMaterial:Blind:EquivalentLayer object (I am aware I am omitting visible properties. I am not interested in these and the exmple IDF shows they are not required):
WindowMaterial:Blind:EquivalentLayer,
WMTEUQL_BLND_KINDV_RF80_T02_A18_Rb45,          !- Name
Vertical,              !- Slat Orientation
0.127,                        !- Slat Width {m}
0.127,                        !- Slat Separation {m}
0.0000,                  !- Slat Crown {m}
45,                      !- Slat Angle {deg}
0.02,                        !- Front Side Slat Beam-Diffuse Solar Transmittance
0.02,                        !- Back Side Slat Beam-Diffuse Solar Transmittance {dimensionless}
0.80,                        !- Front Side Slat Beam-Diffuse Solar Reflectance {dimensionless}
0.45,                        !- Back Side Slat Beam-Diffuse Solar Reflectance {dimensionless}
,                        !- Front Side Slat Beam-Diffuse Visible Transmittance {dimensionless}
,                        !- Back Side Slat Beam-Diffuse Visible Transmittance {dimensionless}
,                        !- Front Side Slat Beam-Diffuse Visible Reflectance {dimensionless}
,                        !- Back Side Slat Beam-Diffuse Visible Reflectance {dimensionless}
0.02,                        !- Slat Diffuse-Diffuse Solar Transmittance {dimensionless}
0.80,                        !- Front Side Slat Diffuse-Diffuse Solar Reflectance {dimensionless}
0.45,                        !- Back Side Slat Diffuse-Diffuse Solar Reflectance {dimensionless}
,                        !- Slat Diffuse-Diffuse Visible Transmittance
,                        !- Front Side Slat Diffuse-Diffuse Visible Reflectance {dimensionless}
,                        !- Back Side Slat Diffuse-Diffuse Visible Reflectance {dimensionless}
,                        !- Slat Infrared Transmittance
0.9,                     !- Front Side Slat Infrared Emissivity {dimensionless}
0.9,                     !- Back Side Slat Infrared Emissivity {dimensionless}
FixedSlatAngle;          !- Slat Angle Control
