Hello All,
I am making a simple PID controller in BCVTB using EnergyPlus.
In my model, I have a Simulator actor(called HouseModel in the image) that connects to EnergyPlus (v9.0.1).
It takes setpoint temperature for cooling an heating thermostat as inputs array (for example, [16; 20]).
In the SystemCommnad actor (called PyController in the image), I have written a P-controller in Python file, as shown below,
import sys
setRef = sys.argv[1]
currTemp = sys.argv[2]
error = float(setRef) - float(currTemp)
# P-Controller
kP = 10
out = kP*error
value = {out, 20}
print(value)
sys.exit(0)
As the EnergyPlus model is expecting an array input, how do I convert the Output of the PyController to a usable array for HouseModel?
I also thought of using FileReader actor in Ptolemy and write the values in the file and then read it from them, but I could not find any good example of that to see how exactly I can use it.
If you have any good examples, I will love to try them.
