Hi, I'm modeling a cooling tower for the baseline building with E+ 8.5.
The cooling tower must be autosized with 1.15 factor (https://comnet.org/383-cooling-towers). I'm using the object "CoolingTower:TwoSpeed". As I read from the documentation, from the capacity I get the air flow rate, and finally the fan power.
How can I autosize it? Is the field "High speed nominal capacity"? The pont is that it can't be "autosize" if I'm not wrong.
Thank you
