I am trying to simulate an .idf file that has been exported from DB, Version 5 (i.e. compatible for E+ 8.6), and has components added from the sample 5ZoneSwimmingPool.idf file. At first I had two "pools" - a pool and a hot tub, but took the hot tub out, when I read in another thread that two pool definitions in E+ 8.6 can cause the crash.
I now only have one pool component and when I run the simulation, it crashes. My errors are all warnings - I do not see severe or fatal errors and I'm not sure what needs to be corrected next.
Does anyone know what is likely causing the crash? What should my next steps be to correct this issue?
Thanks!
Program Version,EnergyPlus, Version 8.6.0-198c6a3cff, YMD=2019.04.17 14:53,IDD_Version 8.6.0
*** ************* Beginning Zone Sizing Calculations
* Warning * ** Warning ** GetHTSubSurfaceData: A Multiplier > 1.0 for window/glass door COMMUNITYCENTRE:PREXSCHOOL_WALL_3_0_0_0_0_0_WIN
* ~~~ * ** ~~~ ** in conjunction with SolarDistribution = FullExterior or FullInteriorExterior
* ~~~ * ** ~~~ ** can cause inaccurate shadowing on the window and/or
* ~~~ * ** ~~~ ** inaccurate interior solar distribution from the window.
* Warning * ** Warning ** GetHTSubSurfaceData: A Multiplier > 1.0 for window/glass door COMMUNITYCENTRE:GYMNASIUM_WALL_1_0_0_0_0_0_WIN
* Warning * ** Warning ** GetHTSubSurfaceData: A Multiplier > 1.0 for window/glass door COMMUNITYCENTRE:GYMNASIUM_WALL_2_0_0_0_0_0_WIN
* Warning * ** Warning ** GetHTSubSurfaceData: A Multiplier > 1.0 for window/glass door COMMUNITYCENTRE:BOCCECOURTS_WALL_8_0_0_0_0_0_WIN
* Warning * ** Warning ** GetHTSubSurfaceData: A Multiplier > 1.0 for window/glass door COMMUNITYCENTRE:FITNESSROOM_WALL_5_0_0_0_0_0_WIN
* Warning * ** Warning ** GetHTSubSurfaceData: A Multiplier > 1.0 for window/glass door COMMUNITYCENTRE:POOLAREA_WALL_2_0_0_0_0_0_WIN
* Warning * ** Warning ** GetHTSubSurfaceData: A Multiplier > 1.0 for window/glass door COMMUNITYCENTRE:POOLAREA_WALL_3_0_0_0_0_0_WIN
* Warning * ** Warning ** GetHTSubSurfaceData: A Multiplier > 1.0 for window/glass door COMMUNITYCENTRE:MAINCORRIDOR1_WALL_1_0_0_0_0_0_WIN
* Warning * ** Warning ** GetHTSubSurfaceData: A Multiplier > 1.0 for window/glass door COMMUNITYCENTRE:ACTIVITYROOM3_WALL_6_0_0_0_0_0_WIN
* Warning * ** Warning ** GetSurfaceData: Construction PROJECT SEMI-EXPOSED CEILING_REVERSED of interzone surface ROOF1:ZONE1_FLOOR_2_1_0 does not have the same materials in the reverse order as the construction PROJECT SEMI-EXPOSED CEILING_REVERSED_REV of adjacent surface COMMUNITYCENTRE:MAINCORRIDOR2_CEILING_0_0_10000
* ~~~ * ** ~~~ ** ...but Nominal U values are similar, diff=[0.0000] ... simulation proceeds.
* ~~~ * ** ~~~ ** ...if the two zones are expected to have significantly different temperatures, the proper "reverse" construction should be created.
* ~~~ * ** ~~~ ** ...this problem for this pair will not be reported again.
* Warning * ** Warning ** GetSurfaceData: Construction PROJECT PARTITION of interzone surface COMMUNITYCENTRE:WC1_PARTITION_1_0_0 does not have the same materials in the reverse order as the construction PROJECT PARTITION_REV of adjacent surface COMMUNITYCENTRE:ACTIVITYROOM2_PARTITION_4_0_10002
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="ROOF1:ZONE1" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=114.20, Calculated Zone Floor Area value=140.92, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="ROOF2:ZONE1" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=90.11, Calculated Zone Floor Area value=113.49, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:WC1" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=4.18, Calculated Zone Floor Area value=5.04, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:STORAGE1" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=6.59, Calculated Zone Floor Area value=8.40, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:STAIRS" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=4.50, Calculated Zone Floor Area value=5.72, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:CONCXAREA" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=9.80, Calculated Zone Floor Area value=11.20, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:OFFICE" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=10.87, Calculated Zone Floor Area value=13.72, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:KILN" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=6.74, Calculated Zone Floor Area value=8.76, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:PARKSSTORAGE" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=9.92, Calculated Zone Floor Area value=13.34, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:ACTIVITYROOM1" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=88.03, Calculated Zone Floor Area value=94.81, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:KITCHEN" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=5.75, Calculated Zone Floor Area value=6.78, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:ACTIVITYROOM2" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=51.69, Calculated Zone Floor Area value=57.00, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:ACTIVITYROOM4" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=38.31, Calculated Zone Floor Area value=42.43, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:SPRINKLERRM" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=5.05, Calculated Zone Floor Area value=6.96, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:MWC1" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=13.47, Calculated Zone Floor Area value=15.21, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:JANTXSTRGX" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=4.01, Calculated Zone Floor Area value=5.53, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:WWC1" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=14.13, Calculated Zone Floor Area value=18.00, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:WORKJANTXRM" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=13.94, Calculated Zone Floor Area value=15.56, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:WWC2" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=21.37, Calculated Zone Floor Area value=23.28, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:STORAGE2" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=9.18, Calculated Zone Floor Area value=10.44, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:WC" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=4.08, Calculated Zone Floor Area value=4.94, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:PREXSCHOOL" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=90.46, Calculated Zone Floor Area value=97.98, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:MWC" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=19.76, Calculated Zone Floor Area value=21.63, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:STORAGE3" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=11.34, Calculated Zone Floor Area value=12.76, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:STAFFLOUNGE" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=39.86, Calculated Zone Floor Area value=43.36, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:SERVERY" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=18.09, Calculated Zone Floor Area value=20.01, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:BOCCISTRG" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=24.00, Calculated Zone Floor Area value=26.18, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:STORAGE4" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=13.50, Calculated Zone Floor Area value=15.08, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:CORRXMAINTX" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=13.53, Calculated Zone Floor Area value=16.87, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:OUTDOORMAINTX" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=18.64, Calculated Zone Floor Area value=21.61, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:GYMNASIUM" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=571.00, Calculated Zone Floor Area value=607.75, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:SOCCEROFFSTRG" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=14.53, Calculated Zone Floor Area value=19.16, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:MCHANGERM" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=19.34, Calculated Zone Floor Area value=23.31, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:CORRXCHNGRM" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=4.69, Calculated Zone Floor Area value=5.96, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:WSHOWER" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=23.25, Calculated Zone Floor Area value=28.23, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:FIRSTAID" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=8.88, Calculated Zone Floor Area value=11.34, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:POOLSTORAGE" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=23.71, Calculated Zone Floor Area value=28.35, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:MECHXROOM" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=72.75, Calculated Zone Floor Area value=80.01, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:SPINROOM" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=88.54, Calculated Zone Floor Area value=95.00, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:WMWC" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=28.00, Calculated Zone Floor Area value=32.24, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:MAINCHANGEROOM" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=32.64, Calculated Zone Floor Area value=34.97, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:MSHOWERWC" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=46.48, Calculated Zone Floor Area value=52.95, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:WWC" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=13.64, Calculated Zone Floor Area value=15.19, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:CORRXWCS" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=4.36, Calculated Zone Floor Area value=5.37, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:CORRIDORFITPOOL" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=54.49, Calculated Zone Floor Area value=60.60, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:WCHANGERM" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=16.32, Calculated Zone Floor Area value=18.07, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:OFFICES2" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=21.99, Calculated Zone Floor Area value=24.16, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:POOLAREA" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=272.82, Calculated Zone Floor Area value=298.52, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:CONTROLDESK" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=39.52, Calculated Zone Floor Area value=41.72, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:OFFICES1" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=35.82, Calculated Zone Floor Area value=38.49, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:FITNESSSTORAGE" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=43.35, Calculated Zone Floor Area value=48.37, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:MAINCORRIDOR2" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=259.95, Calculated Zone Floor Area value=281.52, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="COMMUNITYCENTRE:STAFFOFFICE" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=17.52, Calculated Zone Floor Area value=19.34, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="POOLDEPTH:POOLDEPTH" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=542.81, Calculated Zone Floor Area value=570.40, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: Entered Floor Area entered for Zone="MECHXBASEMENT:ZONE1" significantly different from calculated Floor Area
* ~~~ * ** ~~~ ** Entered Zone Floor Area value=133.03, Calculated Zone Floor Area value=146.85, entered Floor Area will be used in calculations.
* Warning * ** Warning ** GetSurfaceData: There are 9 window/glass door(s) that may cause inaccurate shadowing due to Solar Distribution.
* ~~~ * ** ~~~ ** For explicit details on each window, use Output:Diagnostics,DisplayExtraWarnings;
*** ************* Note that the following warning(s) may/will occur if you have not enclosed your zone completely.
* Warning * ** Warning ** Entered Volume entered for Zone="ROOF1:ZONE1" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=99.66, Calculated Zone Volume value=148.16, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="ROOF2:ZONE1" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=71.88, Calculated Zone Volume value=110.65, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:WC1" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=15.88, Calculated Zone Volume value=19.15, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:STORAGE1" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=25.05, Calculated Zone Volume value=31.92, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:STAIRS" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=16.65, Calculated Zone Volume value=21.74, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:CONCXAREA" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=37.25, Calculated Zone Volume value=42.56, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:OFFICE" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=40.22, Calculated Zone Volume value=52.14, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:KILN" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=25.60, Calculated Zone Volume value=33.31, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:PARKSSTORAGE" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=37.70, Calculated Zone Volume value=50.69, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:ACTIVITYROOM1" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=334.52, Calculated Zone Volume value=360.30, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:KITCHEN" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=21.87, Calculated Zone Volume value=25.76, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:ACTIVITYROOM2" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=196.43, Calculated Zone Volume value=216.59, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:ACTIVITYROOM4" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=145.56, Calculated Zone Volume value=161.25, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:SPRINKLERRM" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=19.19, Calculated Zone Volume value=26.45, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:MWC1" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=51.19, Calculated Zone Volume value=57.80, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:JANTXSTRGX" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=15.24, Calculated Zone Volume value=21.01, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:WWC1" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=53.71, Calculated Zone Volume value=68.39, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:WORKJANTXRM" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=52.98, Calculated Zone Volume value=59.11, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:STAFFMAINTENTRY" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=12.78, Calculated Zone Volume value=19.85, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:STAIRSTOROOF" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=44.73, Calculated Zone Volume value=55.90, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:WWC2" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=81.22, Calculated Zone Volume value=88.45, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:STORAGE2" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=34.88, Calculated Zone Volume value=39.67, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:WC" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=15.50, Calculated Zone Volume value=18.77, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:PREXSCHOOL" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=343.74, Calculated Zone Volume value=372.32, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:MWC" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=75.08, Calculated Zone Volume value=82.20, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:STORAGE3" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=43.09, Calculated Zone Volume value=48.49, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:STAFFLOUNGE" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=151.47, Calculated Zone Volume value=164.77, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:SERVERY" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=68.74, Calculated Zone Volume value=76.04, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:BOCCISTRG" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=91.20, Calculated Zone Volume value=99.48, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:STORAGE4" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=51.30, Calculated Zone Volume value=57.30, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:CORRXMAINTX" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=51.40, Calculated Zone Volume value=64.09, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:OUTDOORMAINTX" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=70.84, Calculated Zone Volume value=82.11, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:GYMNASIUM" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=4368.17, Calculated Zone Volume value=4649.29, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:SOCCEROFFSTRG" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=55.23, Calculated Zone Volume value=72.80, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:MCHANGERM" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=73.48, Calculated Zone Volume value=88.58, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:CORRXCHNGRM" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=17.81, Calculated Zone Volume value=22.63, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:WSHOWER" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=86.03, Calculated Zone Volume value=107.26, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:FIRSTAID" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=33.74, Calculated Zone Volume value=43.09, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:POOLSTORAGE" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=90.09, Calculated Zone Volume value=107.73, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:MECHXROOM" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=276.45, Calculated Zone Volume value=304.04, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:SPINROOM" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=336.44, Calculated Zone Volume value=361.00, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:WMWC" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=106.41, Calculated Zone Volume value=122.51, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:MAINCHANGEROOM" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=124.05, Calculated Zone Volume value=132.89, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:MSHOWERWC" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=176.62, Calculated Zone Volume value=201.20, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:WWC" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=51.83, Calculated Zone Volume value=57.73, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:CORRXWCS" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=16.58, Calculated Zone Volume value=20.41, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:CORRIDORFITPOOL" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=207.06, Calculated Zone Volume value=230.27, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:WCHANGERM" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=60.39, Calculated Zone Volume value=68.66, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:POOL" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=1419.39, Calculated Zone Volume value=481.43, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:OFFICES2" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=83.58, Calculated Zone Volume value=91.82, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:POOLAREA" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=1555.06, Calculated Zone Volume value=2694.30, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:MAINCORRIDOR1" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=1288.88, Calculated Zone Volume value=3292.26, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:OFFICES1" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=136.11, Calculated Zone Volume value=146.26, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:FITNESSSTORAGE" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=251.45, Calculated Zone Volume value=280.55, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:MAINCORRIDOR2" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=959.86, Calculated Zone Volume value=1069.82, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="COMMUNITYCENTRE:STAFFOFFICE" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=64.83, Calculated Zone Volume value=73.48, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="SKYLIGHTNW:ZONE1" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=42.30, Calculated Zone Volume value=73.33, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="SKYLIGHTSW:ZONE1" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=35.60, Calculated Zone Volume value=62.04, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="POOLDEPTH:POOLDEPTH" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=1085.61, Calculated Zone Volume value=1140.80, entered volume will be used in calculations.
* Warning * ** Warning ** Entered Volume entered for Zone="MECHXBASEMENT:ZONE1" significantly different from calculated Volume
* ~~~ * ** ~~~ ** Entered Zone Volume value=266.06, Calculated Zone Volume value=293.71, entered volume will be used in calculations.
* Warning * ** Warning ** CheckUsedConstructions: There are 9 nominally unused constructions in input.
* ~~~ * ** ~~~ ** Each Unused construction is shown.
*** ************* Construction=LINEARBRIDGINGCONSTRUCTION
*** ************* Construction=FECC_BRICK EXTERNAL WALL 2 R-17.8 (RSI-3.13)_REV
*** ************* Construction=PROJECT UNOCCUPIED PITCHED ROOF_REV
*** ************* Construction=FECC_FLAT ROOF R-27.0 (RSI-4.76)_REV
*** ************* Construction=FECC_FOUNDATION (NO DETAILS GUESS)_REV
*** Con
************* Con
