Hello, I have a problem when I tried to import a .idf file to OpenStudio. Here are the details about the error.
The collection is INVALID at strictness level 'Draft', because of the errors: Field level data error of type DataType . Error is in an object of type 'RunPeriod', named 'Run Period 1', in field 5. Additional information about the error type: field-level data is of an incorrect type. Field level data error of type NumericBound . Error is in an object of type 'RunPeriod', named 'Run Period 1', in field 4. Additional information about the error type: numeric data violates a min or max bound.
Is this text referring to a syntax error? Here is the RunPeriod text part of the .idf file.
RunPeriod, Run Period 1, !- Name 1, !- Begin Month 1, !- Begin Day of Month 12, !- End Month 31, !- End Day of Month Monday, !- Day of Week for Start Day No, !- Use Weather File Holidays and Special Days No, !- Use Weather File Daylight Saving Period No, !- Apply Weekend Holiday Rule Yes, !- Use Weather File Rain Indicators Yes, !- Use Weather File Snow Indicators 1, !- Number of Times RunPeriod to be Repeated , !- Increment Day of Week on repeat 2018; !- Start Year
I have checked the object RunPeriod in my .idf file and it doesn't make sense to me because the fields 4 and 5 were already filled in correctly (or have I mistaken?). The current .idf file and EnergyPlus version that I am using are 8.9. Could you tell me how I should tackle this problem or if you have any solution? I have tried to solve it but I couldn't find any solution so I am asking for your help. If you need additional information to understand the problem please tell me. Thank you in advance.
