Hello all, I have a detailed system with an AHU with a cooling and heating coil serving one zone. I'm combining a Single Zone Heating and Single Zone Cooling Setpoint Managers for the generic air loop, but I'm not sure if this is the best set-point manager to use... if I employ the warmest setpoint manager the gas consumption decreases quite a bit. Would using either of the set point managers (i.e. a Single Zone Heating and Single Zone Cooling Setpoint Managers or only using the warmest) be correct? Also, I do not understand very well if I use the warmest setpoint manager how the heating is controlled. Thanks a lot!
