eppy functionality and WINDOW7-generated BSDFs
I'm having a great time using the eppy library (thanks authors!) and just curious: will eppy handle ok idfs that contain window + complex shade BSDF info exported from WINDOW7 in idf form, including Basis Matrix and Matrix Data?
My plan is to just append the window BSDF idf generated by WINDOW7 into my main idf (linking via the WindowProperty:FrameAndDivider and Construction:ComplexFenestrationState names) and then reading in with eppy.
Thanks for any thoughts!
