Hi! I'm using Euclid plugin in order to draw the geometry in SketchUp, I'm drawing a very simple geometry which includes a window. In SketchUp, I'm using the "search surface" tool to make sure that I've drawn the window correctly (it recognizes the window as an "Exterior Window" construction, so I assume the window is OK). When I open the .idf file in Open Studio the Window doesn't exist anymore, niether in the Geometry tab nor in the Spaces tab as a subsurface. Any ideas of what I might be doing wrongly? Thanks in advance.
