I'm having trouble running the Radiance Daylighting Measures in the OS PAT 2.7.0, getting the following error:
[10:10:54.312978 ERROR] No such file or directory @ dir_s_mkdir - C:/Users/LKECK/Documents/AEI/Working/OS_PAT/OSU_Shade_Test_1/OSU_Shade_Test/temp_data/analysis_1e2d57c7-0113-40ea-b922-7ceffef4640c/data_point_9f7a5d65-d099-440c-8285-2d56b04a069e/run/001_Radiance Daylighting Measure/radiance/output/dc/merged_space
:/ruby/2.2.0/fileutils.rb:252:in `mkdir'
:/ruby/2.2.0/fileutils.rb:252:in `fu_mkdir'
:/ruby/2.2.0/fileutils.rb:226:in `block (2 levels) in mkdir_p'
:/ruby/2.2.0/fileutils.rb:224:in `reverse_each'
:/ruby/2.2.0/fileutils.rb:224:in `block in mkdir_p'
:/ruby/2.2.0/fileutils.rb:210:in `each'
:/ruby/2.2.0/fileutils.rb:210:in `mkdir_p'
C:/Users/LKECK/Documents/AEI/Working/OS_PAT/OSU_Shade_Test_1/OSU_Shade_Test/temp_data/analysis_1e2d57c7-0113-40ea-b922-7ceffef4640c/measures/Radiance Daylighting Measure/measure.rb:696:in `run'
C:/openstudio-2.7.0/pat/OpenStudio-server/gems/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/measure.rb:467:in `apply_measure'
C:/openstudio-2.7.0/pat/OpenStudio-server/gems/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/measure.rb:74:in `block in apply_measures'
C:/openstudio-2.7.0/pat/OpenStudio-server/gems/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/measure.rb:32:in `each_index'
C:/openstudio-2.7.0/pat/OpenStudio-server/gems/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/measure.rb:32:in `apply_measures'
C:/openstudio-2.7.0/pat/OpenStudio-server/gems/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/jobs/run_os_measures.rb:52:in `perform'
C:/openstudio-2.7.0/pat/OpenStudio-server/gems/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/run.rb:269:in `step'
C:/openstudio-2.7.0/pat/OpenStudio-server/gems/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/run.rb:216:in `run'
:/openstudio_cli.rb:920:in `execute'
:/openstudio_cli.rb:709:in `execute'
:/openstudio_cli.rb:1686:in `<main>'
eval:110:in `eval'
eval:110:in `require_embedded_absolute'
eval:95:in `block in require'
eval:89:in `each'
eval:89:in `require'
eval:2:in `<main>'
Any thoughts or suggestions? It appears to be a path or directory issue, maybe?
