I am modifying an OpenStudio measure (Replace HVAC with WSHP and DOAS) to create a DOAS with dehumidification. I tried to add “CoilSystem:Cooling:DX” but there is no object for it in OpenStudio model documentation, but it is created in the in.idf file after running the simulation so I am assuming its created when the model is translated to EnergyPlus. Is there a code line I can drop in the measure to access the fields of this object? Or should I create an EnergyPlus measure to modify these fields.
Thank you,
