How to use HVACTemplate:Plant:Chiller:ObjectReference?
I wanted to input actual chiller performance curve using HVACTemplate. That's why I used HVACTemplate:Plant:Chiller:ObjectReference with HVACTemplate:ChillerWaterLoop and Chiller:Electric:EIR. Howerver, I got fatal error because I didnt fill in Chilled Water Inlet Node Name and Chilled Water Outlet Node Name. However, I expected that I dont have to worry about Inlet and Outlet because HVACTemplate will take care of it. Does anyone know how I can use HVACTemplate:Plant:Chiller:ObjectReference with Chiller:Electric:EIR?
I added corresponding part in idf as below.
!-   ===========  ALL OBJECTS IN CLASS: HVACTEMPLATE:PLANT:CHILLEDWATERLOOP ===========
HVACTemplate:Plant:ChilledWaterLoop,
    CHWloop,                 !- Name
    ALWAYS ON,               !- Pump Schedule Name
    Intermittent,            !- Pump Control Type
    Default,                 !- Chiller Plant Operation Scheme Type
    ,                        !- Chiller Plant Equipment Operation Schemes Name
    ,                        !- Chilled Water Setpoint Schedule Name
    6.7,                     !- Chilled Water Design Setpoint {C}
    VariablePrimaryNoSecondary,  !- Chilled Water Pump Configuration
    116300.0,                !- Primary Chilled Water Pump Rated Head {Pa}
    232700.0,                !- Secondary Chilled Water Pump Rated Head {Pa}
    Default,                 !- Condenser Plant Operation Scheme Type
    ,                        !- Condenser Equipment Operation Schemes Name
    ,                        !- Condenser Water Temperature Control Type
    ,                        !- Condenser Water Setpoint Schedule Name
    28.3,                    !- Condenser Water Design Setpoint {C}
    310000.0,                !- Condenser Water Pump Rated Head {Pa}
    OutdoorAirTemperatureReset,  !- Chilled Water Setpoint Reset Type
    12,                      !- Chilled Water Setpoint at Outdoor Dry-Bulb Low {C}
    16,                      !- Chilled Water Reset Outdoor Dry-Bulb Low {C}
    7,                       !- Chilled Water Setpoint at Outdoor Dry-Bulb High {C}
    27,                      !- Chilled Water Reset Outdoor Dry-Bulb High {C}
    PumpPerChiller,          !- Chilled Water Primary Pump Type
    SinglePump,              !- Chilled Water Secondary Pump Type
    SinglePump,              !- Condenser Water Pump Type
    Yes,                     !- Chilled Water Supply Side Bypass Pipe
    Yes,                     !- Chilled Water Demand Side Bypass Pipe
    Yes,                     !- Condenser Water Supply Side Bypass Pipe
    Yes,                     !- Condenser Water Demand Side Bypass Pipe
    Water,                   !- Fluid Type
    6.67,                    !- Loop Design Delta Temperature {deltaC}
    ,                        !- Minimum Outdoor Dry Bulb Temperature {C}
    SequentialLoad,          !- Chilled Water Load Distribution Scheme
    SequentialLoad;          !- Condenser Water Load Distribution Scheme
!-   ===========  ALL OBJECTS IN CLASS: HVACTEMPLATE:PLANT:CHILLER:OBJECTREFERENCE ===========
HVACTemplate:Plant:Chiller:ObjectReference,
    OilFreeChiller1,         !- Name
    Chiller:Electric:EIR,    !- Chiller Object Type
    OilFreeChiller1,         !- Chiller Name
    ;                        !- Priority
    OilFreeChiller2,         !- Name
    OilFreeChiller2,         !- Chiller Name
    ;                        !- Priority
    OilFreeChiller3,         !- Name
    OilFreeChiller3,         !- Chiller Name
    ;                        !- Priority
    OilFreeChiller4,         !- Name
    OilFreeChiller4,         !- Chiller Name
    ;                        !- Priority
!-   ===========  ALL OBJECTS IN CLASS: CHILLER:ELECTRIC:EIR ===========
    2461800,                 !- Reference Capacity {W}
    5.8,                     !- Reference COP {W/W}
    6.67,                    !- Reference Leaving Chilled Water Temperature {C}
    29.4,                    !- Reference Entering Condenser Fluid Temperature {C}
    ,                        !- Reference Chilled Water Flow Rate {m3/s}
    ,                        !- Reference Condenser Fluid Flow Rate {m3/s}
    OilFreeChiller_CAPFT,    !- Cooling Capacity Function of Temperature Curve Name
    OilFreeChiller_EIRFT,    !- Electric Input to Cooling Output Ratio Function of Temperature Curve Name
    OilFree_EIRPLR,          !- Electric Input to Cooling Output Ratio Function of Part Load Ratio Curve Name
    0.1,                     !- Minimum Part Load Ratio
    1,                       !- Maximum Part Load Ratio
    1,                       !- Optimum Part Load Ratio
    0.2,                     !- Minimum Unloading Ratio
    ,                        !- Chilled Water Inlet Node Name
    ,                        !- Chilled Water Outlet Node Name
    ,                        !- Condenser Inlet Node Name
    ,                        !- Condenser Outlet Node Name
    WaterCooled,             !- Condenser Type
    ,                        !- Condenser Fan Power Ratio {W/W}
    1,                       !- Fraction of Compressor Electric Consumption Rejected by Condenser
    2,                       !- Leaving Chilled Water Lower Temperature Limit {C}
    NotModulated,            !- Chiller Flow Mode
    ,                        !- Design Heat Recovery Water Flow Rate {m3/s}
    ,                        !- Heat Recovery Inlet Node Name
    ,                        !- Heat Recovery Outlet Node Name
    1,                       !- Sizing Factor
    ,                        !- Basin Heater Capacity {W/K}
    2,                       !- Basin Heater Setpoint Temperature {C}
    ,                        !- Basin Heater Operating Schedule Name
    ,                        !- Condenser Heat Recovery Relative Capacity Fraction
    ,                        !- Heat Recovery Inlet High Temperature Limit Schedule Name
    ,                        !- Heat Recovery Leaving Temperature Setpoint Node Name
    General;                 !- End-Use Subcategory
    1,                       !- Sizing Factor
    1,                       !- Sizing Factor
    527528,                  !- Reference Capacity {W}
    1,                       !- Sizing Factor
    CHWloop,                 !- Name
    ;                        !- Priority
    ;                        !- Priority
    ;                        !- Priority
    ;                        !- Priority
    1,                       !- Sizing Factor
    1,                       !- Sizing Factor
    1,                       !- Sizing Factor
    1,                       !- Sizing Factor
