Hi Everyone,
My objective is to control the heating and cooling availability schedule of zoneHvac:IdealAirLoadSystem. I take the following steps.
1) Define a heating and cooling availability on/off schedule in Schedule : Compact, set initial value to 1. 2) Use EMS sensor to get the zone temperature which is used late in EMS program 3) Define EMS Actuator to control heating and cooling availability schedule of IdealAirLoadSystem 4) Define the EMS program to activate the actuator
My Eplus objects are detailed below. I am not sure which calling point to use? No matter which calling point I choose the value of heating and cooling availability doesn't change from 1.
I'd appreciate any help.
Thanks
**Schedule:Compact,
HeaAva, !- Name
On/Off, !- Schedule Type Limits Name
Through: 12/31, !- Field 1
For: Alldays, !- Field 2
Until: 24:00, !- Field 3
1; !- Field 4
Schedule:Compact,
CooAva, !- Name
1; !- Field 4
ZoneHVAC:IdealLoadsAirSystem,
WestZoneIdealAir, !- Name
, !- Availability Schedule Name
Zone1Inlets, !- Zone Supply Air Node Name
, !- Zone Exhaust Air Node Name
, !- System Inlet Air Node Name
50, !- Maximum Heating Supply Air Temperature {C}
13, !- Minimum Cooling Supply Air Temperature {C}
0.015, !- Maximum Heating Supply Air Humidity Ratio {kgWater/kgDryAir}
0.01, !- Minimum Cooling Supply Air Humidity Ratio {kgWater/kgDryAir}
NoLimit, !- Heating Limit
, !- Maximum Heating Air Flow Rate {m3/s}
, !- Maximum Sensible Heating Capacity {W}
NoLimit, !- Cooling Limit
, !- Maximum Cooling Air Flow Rate {m3/s}
, !- Maximum Total Cooling Capacity {W}
HeaAva, !- Heating Availability Schedule Name
CooAva, !- Cooling Availability Schedule Name
ConstantSupplyHumidityRatio, !- Dehumidification Control Type
, !- Cooling Sensible Heat Ratio {dimensionless}
ConstantSupplyHumidityRatio, !- Humidification Control Type
, !- Design Specification Outdoor Air Object Name
, !- Outdoor Air Inlet Node Name
, !- Demand Controlled Ventilation Type
, !- Outdoor Air Economizer Type
, !- Heat Recovery Type
, !- Sensible Heat Recovery Effectiveness {dimensionless}
; !- Latent Heat Recovery Effectiveness {dimensionless}**
!- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:SENSOR ===========
EnergyManagementSystem:Sensor,
ZoneTemp, !- Name
West Zone, !- Output:Variable or Output:Meter Index Key Name
Zone Mean Air Temperature ; !- Output:Variable or Output:Meter Name
!- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:ACTUATOR ===========
HeaAvaActuator, !- Name
HeaAva, !- Actuated Component Unique Name
Schedule:Compact, !- Actuated Component Type
Schedule Value; !- Actuated Component Control Type
CooAvaActuator, !- Name
CooAva, !- Actuated Component Unique Name
!- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:PROGRAMCALLINGMANAGER ===========
myPrograms, !- Name
EndOfSystemTimestepAfterHVACReporting, !- EnergyPlus Model Calling Point
HeatingAvailabilityProgram, !- Program Name 1
CoolingAvailabilityProgram; !- Program Name 2
!- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:PROGRAM ===========
HeatingAvailabilityProgram, !- Name
IF (ZoneTemp < 19 ), !- Program Line 1
SET HeaAva = 1, !- Program Line 2
ELSE, !- A4
SET HeaAva = 0, !- A5
ENDIF; !- A6
CoolingAvailabilityProgram, !- Name
IF (ZoneTemp > 25 ), !- Program Line 1
SET CooAva = 1, !- Program Line 2
ELSE, !- A4
SET CooAva = 0, !- A5
ENDIF; !- A6
