Some 90.1 schedules start HVAC after receptacle / lighting loads?
The ASHRAE Std. 90.1-2013 User's Manual contains schedules for various building types & functions. I noticed that a few of them follow a pattern where the lighting & receptacle loads ramp up an hour prior to the HVAC system operation. This seems a little bit odd because that would mean in some cases that space temperatures could start rising before the A/C is capable of controlling them.
Here's an example, for the Office building schedule:
Are these schedules meant to represent actual typical building operation? Or were they constructed this way for some other reason?
Note that in the original Std. 90.1-1989 (the last year these schedules were included in 90.1 itself) the Office schedule was actually a little different and had the plug loads & HVAC schedules come on at the same time. This seems to further muddy the waters - why was a revision to this schedule made (at some point in time)?
Thanks
Note that
Furthermore, in the original Std. 90.1-1989 (the last year these schedules were included in 90.1 itself) the Office schedule was actually a little different and had the plug loads & HVAC schedules come on at the same time. This seems to further muddy the waters - why was a revision to this schedule made (at some point in time)?
Thanks
Thanks
Thanks
Some Why do some 90.1 schedules start HVAC after equipment later than receptacle / lighting loads?
Thanks
Why do some 90.1 schedules start HVAC equipment later than receptacle / lighting loads?
Thanks
