I have a HeatExchanger:AirToAir:SensibleAndLatent object that is generating this error.
** Warning ** HeatExchanger:AirToAir:SensibleAndLatent "DOAS HEAT RECOVERY"
** ~~~ ** Average air volume flow rate is <50% or >130% of the nominal HX supply air volume flow rate.
** ~~~ ** Air volume flow rate ratio = 0.446. Environment=MIAMI INTL AP ANN HTG 99.6% CONDNS DB, at Simulation time=01/21 00:00 - 00:15
************* ** Warning ** HeatExchanger:AirToAir:SensibleAndLatent "DOAS HEAT RECOVERY": Average air volume flow rate is <50% or >130% warning continues. Air flow rate ratio statistics follow.
************* ** ~~~ ** This error occurred 830 total times;
************* ** ~~~ ** during Warmup 0 times;
************* ** ~~~ ** during Sizing 0 times.
************* ** ~~~ ** Max=0.499836 Min=0.438976
Looking in the engineering reference,
but the Nominal Supply Air Flow Rate field is autosized.
Is there a recommended way to fix the error?
