OutPut Variable error
Hello all, I Try to edit and simulate the command line interface, workflow example. I want to get the "zone air temperature, hourly" output variable as results in excel file, Hence I added to my workflow two measures -"add an output variable", reporting measure- "ExportVariableToCsv".
I get the error "Output:Variable,,Zone Air Temperature,hourly; is not in sqlFile. Please add an AddOutputVariable reporting measure with this variable and run again."
the variable name is depicted in the e+ rdd file. I try other output variables with the same error. Appreciate your help regarding this issue. Thanks
I get the error "Output:Variable,,Zone "Output: Variable,, Zone Air Temperature,hourly; Temperature, hourly; is not in sqlFile. Please add an AddOutputVariable reporting measure with this variable and run again."
the variable name is depicted in the e+ rdd file. I try other output variables with and get the same error same error. Appreciate The add output variable is considered as reporting measure, while when running the ruby script generate_workflow file. false statement is obtained and the add output variable is considered as openstudio measure. appreciate your help regarding this issue. Thanks the right way to extract CSV file for a specific output variable
Thanks
I get the error "Output: Variable,, Zone Air Temperature, hourly; is not in sqlFile. Please add an AddOutputVariable reporting measure with this variable and run again."
the variable name is depicted in the e+ rdd file. I try other output variables and get the same error same error. The add output variable is considered as reporting measure, while when running the ruby script generate_workflow file. false statement is obtained and the add output variable is considered as openstudio measure. appreciate your help regarding the right way to extract CSV file for a specific output variable
Thanks
the variable name is depicted in the e+ rdd file. I try other output variables and get the same error. The add output variable is considered as reporting measure, while when running the ruby script generate_workflow file. false statement is obtained and the add output variable is considered as openstudio measure. appreciate your help regarding the right way to extract CSV file for a specific output variable
Thanks
Thanks
