I was trying to figure out what all the controlling objects do in the example file IceStorage-Series-ChillerUpstream.idf and came upon some strange behavior.
A little background. The plant side of this loop has a pump, chiller, and ice tank. The demand side has a pump and ONE water coil. There is a common pipe between them.
On the night of 3/12 and 3/13, the water coil is not cooling, the ice tank has charge, the ice tank has no flow through the ice tank part, the pump on the demand side is off, the pump on the plant side is on, and the chiller is chilling.
What is going on? All I can imagine is that the chiller is chilling the heat from the pump that's running as the only water coil on the demand side is not providing cooling. Here is a google drive link to the files. All I did to the original file was change the run period and the output variables.
