Hi,
I want to simulate a heat pump which uses drain water as heat source (see attached schematic). The drain water should be held in a tank. Is there any possibility of simulating such system in E-plus?
Thanks
![]() | 1 | initial version |
Hi,
Thanks
![]() | 2 | retagged |
Hi,
Thanks
