I am using a text editor to build an OS measure which sets the occupancy load of a building. In building the measure, I am using the following code to test what the old definitions for occupancy load are:
require 'openstudio'
require 'openstudio/ruleset/ShowRunnerOutput'
require 'test/unit'
class SetNew_Test < Test::Unit::TestCase
def test_SetNew_a
# load the test model
translator = OpenStudio::OSVersion::VersionTranslator.new
path = OpenStudio::Path.new(File.dirname(__FILE__) + "/OldModel.osm")
model = translator.loadModel(path)
assert((not model.empty?))
model = model.get
puts "Model Loaded"
model.getSpaceTypes.each do |space_tp|
#loop through all people definitions in the space type
space_tp.people.each do |people|
#get the old od from the existing definition, if exists
old_people = people.peopleDefinition.peoplePerFloorArea.get
puts old_people
end
end
end
end
I checked the file in OS and the building does define the occupancy load in terms of people per floor area, however, I get the following error from the command line:
undefined method 'peoplePerFloorArea'
I have tried several different classes that should exist, such as lighting power density, schedules, etc. However, each time I get the same error that the method does not exist . . . I would appreciate any comments that might lend some insight into what I am doing wrong
