Hello, I want to simulate several cases of external wall thickness change. I decided to use the "Swap Construction In Construction Set" measure using the workflow https://github.com/UnmetHours/openstudio-scripts/tree/master/OpenStudio_CLI_Template.
Hence, I made several construction sets with changed material width, as can be seen below. The problem is that I cannot understand what is the variable of which the measure is executed. while entering to the measure.rb file no coherent data regarding this issue is obtained.
I try to run this code: with "*new_construction * as variable
cons = ["concrete0.2", "concrete0.3", "concrete0.4"].
new_construction.each do |con| run_name = "new_construction_#{new_construction.to_s.delete(".")}" new_construction = make_cons_change(con) makeOSW(run_name, example_osm_filepath, example_epw_filepath, [new_construction, add_hourly_meters], [], [os_results]) end
I get the error: "undefined local variable or method `new_construction' for main:Object"
What is the correct way to assign variable into this code? Thanks
