Hello, I try to run the workflow example file, as directed in the command line interface documentation. i got an error: C:\openstudio-2.7.0\Examples\compact_osw>"C:\openstudio-2.7.0\bin\openstudio.exe" run -w "C:\openstudio-2.7.0\Examples\compact_osw\compact.osw" [14:43:49.424907 WARN] Measure couldn't find the construction named 'EXTERIOR-WALL adj exterior wall insulation' in the exterior surface hash.
while running the seed file from the OpenstudioApp no error occurred. Can you tell me please what is the reason for this error?
