* Warning * GetDensityGlycol: Temperature is out of range (too low) for fluid [WATER] density * * ~~~ * ..Called From:CalcWatertoWaterHPHeating,Temperature=[-10.99], supplied data range=[0.00,100.00] * ~~~ * Environment=SHANGHAI ANN HTG 99.6% CONDNS DB, at Simulation time=01/21 00:00 - 00:15 * Warning * GetSpecificHeatGlycol: Temperature is out of range (too low) for fluid [WATER] specific heat supplied values * * ~~~ * ..Called From:CalcWatertoWaterHPHeating,Temperature=[-10.99], supplied data range=[0.00,125.00] * ~~~ * Environment=SHANGHAI ANN HTG 99.6% CONDNS DB, at Simulation time=01/21 00:00 - 00:15 * Warning * SolveAirLoopControllers: Maximum iterations (50) exceeded for DOAS SYSTEM-Y, at RUNPERIOD1, 07/11 20:30 - 20:35
