Revit to gbXML to Openstudio 2.7
Hello everyone, I am working on exporting a gbXML file from Revit and opening the same in Openstudio v2.7. For exporting the gbXML from Revit, Using energy settings' andUsing Rooms/Spaces'. I am still missing the curtain wall openings, few walls while I try to export. How do I fix it? For importing the gbXML to OS v2.7, I used the Ladybug tool in the editor. However had the following warnings,
Surface has two adjacent spaces which are the same space 'aim7644', will not be translated. Surface has two adjacent spaces which are the same space 'aim7810', will not be translated. I am unable to view the model and Open Studio screen crashes.
How can I fix this? Am I missing something? Is it not possible to use gbXML file in OS v2.7?Are there steps to follow before converting the Revit file to gbXML. and before importing to OS? Thanks for your help. Ranjani
