Hello,
I´m simulating a thermal zone (25ºC for cooling thermostat schedule) with:
- mechanical ventilation + heat recovery system
- fan-coils with a electric chiller.
I´m realized those fact:
Step 1: Thermal zone with mechanical ventilation off. No problem, the fan coils set the indoor temperature at 25ºC.
Step 2: Thermal zone with mechanical ventilation on. The fan coils don’t reach the 25ºC.
Step 3: Increasing the chiller from 50kW to 500kW. Nothing, moreover, don’t change the graphic.
Step 4: Increasing the cooling sizing parameters (up to 20) and setting the chiller as Autosize. Nothing and it not change the graphic.
How can I improve the fan coil in order to cooling the mechanical ventilation air?
The only solution that I found was:
1. Reducing the air flow rate to nearly zero.
2. Adding a cooling battery in the mechanical ventilation system.
But the project hasn´t got those elements.
Thanks
