The EnergyPlus program appears to return an environment result code of 0 when there were no errors, or can return other values when errors have occurred.
For example, you might get a message such as "Process exited with a non-zero exit code of: 1" from OpenStudio.
Is there a comprehensive list of what the possible return codes are, and their definitions?
Thanks
