Hi! I am getting the following warning message while modelling AirflowNetwork in EnergyPlus:
** Severe ** The number of entered AirflowNetwork:Distribution:Component:Fan objects is 1
** Severe ** The number of entered AirLoopHVAC objects is 0
** ~~~ ** Both numbers should be equal. Please check your inputs.
** Fatal ** GetAirflowNetworkInput: Errors found getting inputs. Previous error(s) cause program termination.
...Summary of Errors that led to program termination:
..... Reference severe error count=2
..... Last severe error=The number of entered AirLoopHVAC objects is 0
I am modelling a HVAC loop with only a supply fan on the supply side and an ideal load on the demand side. The fan is modelled as a constant volume fan and connected to the airloop of the HVAC, so i don't understand when the error says that the number of AirLoopHVAC objects is 0.
Could you please help me? Here is the link
Thank you
