If I add the Cooling Coil Total Cooling Rate
of each coil of my secondary plant, then I end up with a value that is smaller than the ``Plant Supply Side Cooling Demand Rate´´. For me it must be approximately the same value.
The Following picture shows my secondary plant . Circulated in yellow the coil that I mentioned (there is one for each climatized room) .
