In Openstudio, when I downloaded the 8" Concrete Block, whatever solid grouted or unreinforced cells empty, the higher the density is, from 105 to 115 to 125 lb/ft3, the lower the specific heat is. But from the "Guide to Thermal Properties of Concrete and Masonry Systems" or other codes, its opposite. Higher concrete density means higher specific heat. Is there any explanation?
