I'm modeling a cold water loop with OpenStudio 2.7. The loop has three water to water heat pumps on the supply side. The problem that I am facing is that the heat pump objects do not link to any condenser loop. I also tried to both substitute the object with chillers and to reduce the number of objects to one, but the problem still remains. Any idea on how to solve it?
