Set COP Measure Methods
I want to change the COP for WSHP, so I am trying to modify the OS measure below that I found in here, but I did not understand what these two methods do (to_ZoneHVACPackagedTerminalAirConditioner and is_initialized). I searched the documentation for ZoneHVACPackagedTerminalAirConditioner, but did not find any information about what these methods do. Can someone shade some light on these methods and where I can find their documentation?
Thank you,
 # loop through zone equipment
model.getZoneHVACComponents.each do |component|
  # see if it is a PTAC
  if component.to_ZoneHVACPackagedTerminalAirConditioner.is_initialized
    runner.registerInfo("#{component.name} is a PTAC")
    ptac = component.to_ZoneHVACPackagedTerminalAirConditioner.get
    # get the cooling coil
    coil_cooling = ptac.coolingCoil
    # see if it is single speed dx
    if coil_cooling.to_CoilCoolingDXSingleSpeed.is_initialized
      single_speed_dx = coil_cooling.to_CoilCoolingDXSingleSpeed.get
      runner.registerInfo("The intial COP is #{single_speed_dx.ratedCOP}")
      # set cop
      target_cop = 1.5 * single_speed_dx.ratedCOP.get # need the get because ratedCOP returns an optional, should check if it exists before doing a get
      optionalDoubleCOP = OpenStudio::OptionalDouble.new(target_cop) # not many objects need this step, this is an odd one
      single_speed_dx.setRatedCOP(optionalDoubleCOP)
      runner.registerInfo("The adjusted COP is #{single_speed_dx.ratedCOP}")
    else
      # could add in elsif to look for other types of cooling coils
    end
  else
    # could add in elsif to look for other kinds of zone equipment
  end
end
Thank you,
      # set cop
    else
    end
  else
  end
end
Set COP is_initialized and to_ Measure Methods
Thank you,
      # set cop
    else
    end
  else
  end
end
is_initialized Measure Methods (is_initialized and to_ Measure Methodsto_) what they do
Thank you,
      # set cop
    else
    end
  else
  end
end
Measure Methods (is_initialized and to_) what they do
Thank you,
      # set cop
    else
    end
  else
  end
end
Thank you,
      # set cop
    else
    end
  else
  end
end
