I´m testing the radiance tools in Openstudio, and I set three Daylight sensors in the same thermal zone (Linked those sensors in that thermal zone).
The problem is I can´t find the luxes for each sensor. Where can I found it? Is the result in Dview the mean of all sensors? I didnt found those outputs in Result Viewer too, in the archive C:....\000_Radiance Daylighting Measure\radiance\output.sql
Thank you
