I am using ideal air loads in a somewhat unique zone and am getting 8369 unmet cooling hours. I had thought that ideal air loads was designed to meet temperature setpoints no matter what.
Zone characteristics are as follows: - Below grade - All adiabatic boundaries except with the floor above (this was done to avoid additional heat gains from the OS-assumed ground temperature of 18C) - Very large volume - Setpoint of 41F
Could the issue be the outlandishly low setpoint temperature?
