Hi,
I try to update IDF file from version 8.6 to version 9.0 but modified one has all FenestrationSurface:Detailed removed. EP 8.6 could run it successfully. Don't understand why FenestrationSurface:Detailed has been being removed without replacement objects - is it error?
thanks
Conversion 8.6 => 8.7 Starting new Transition.audit Will create new full IDFs Will create new IDF lines with units where applicable Will create new IDF lines leaving blank incoming fields as blank (no default fill) Processing IDF -- G:\new_export.idf
* Warning * Alpha Argument length exceeds maximum, will be truncated= Heated Combined ground floor - State-of-the-art - Heavyweight (data modified when loaded to file)_Rev
* ~~~ * Will be processed as Alpha=Heated Combined ground floor - State-of-the-art - Heavyweight (data modified when loaded to file)_ReConversion 8.7 => 8.8 Starting new Transition.audit Will create new full IDFs Will create new IDF lines with units where applicable Will create new IDF lines leaving blank incoming fields as blank (no default fill) Processing IDF -- G:\new_export.idf
* Warning * Object=FenestrationSurface:Detailed, name=FacultyOfficeXnorth:Zone1XOfficeNorth_Wall_2_2_0_0_0_0_Win, entered with less than minimum number of fields. * ~~~ * Attempting fill to minimum. * Severe * Object=FenestrationSurface:Detailed, name=FacultyOfficeXnorth:Zone1XOfficeNorth_Wall_2_2_0_0_0_0_Win, Required Field=[Vertex 1 Z-coordinate] was blank.
..............Many repeated Warning and all FenestrationSurface:Detailed disappeared in updated idf
