I want to modify the default OS library to add more space types. I am thinking of opening the .osm library file in OpenStudio application add the spaces and save it. Would that work or it would case proplems in the future?
Thank you,
| 1 | initial version |
Thank you,
I want to modify the default OS library to add more space types. I am thinking of opening the .osm library file in OpenStudio application add the spaces space types and save it. Would that work or it would case proplems in the future?
Thank you,
I want to modify the default OS library to add more space types. I am thinking of opening the .osm library file in OpenStudio application add the space types and save it. Would that work or it would case proplems cause problems in the future?
Thank you,
| 4 | retagged |
I want to modify the default OS library to add more space types. I am thinking of opening the .osm library file in OpenStudio application add the space types and save it. Would that work or it would cause problems in the future?
Thank you,
