* Warning * ZoneHVAC:LowTemperatureRadiant:VariableFlow [B-1 RADIANT CEILING] * ~~~ * Surface [B1-CEILING] temperature below dew-point temperature--potential for condensation exists * ~~~ * Flow to the radiant system will be shut-off to avoid condensation * ~~~ * Predicted radiant system surface temperature = 23.85 * ~~~ * Zone dew-point temperature + safety delta T= 24.50 * ~~~ * Environment=SHANGHAI ANN CLG .4% CONDNS DB=>MWB, at Simulation time=07/21 00:15 - 00:30 * ~~~ * Note that a -1.0000 C safety was chosen in the input for the shut-off criteria * ~~~ * Note also that this affects all surfaces that are part of this radiant system
