The E+ model for 'airconditioner:variablerefrigerantflow' does not have defaults for the following curves:
, !- Heat Recovery Cooling Capacity Modifier Curve Name , !- Heat Recovery Cooling Energy Modifier Curve Name , !- Heat Recovery Heating Capacity Modifier Curve Name , !- Heat Recovery Heating Energy Modifier Curve Name
Can someone recommend sources/references for these?
