Dear all,
I tried to make the communication between bcvtb with trnsys18 demo that I had installed in my pc (with windows 10 64 bit) and it failed. The messages were:
* Notice at time : 0.000000 Generated by Unit : Not applicable or not available Generated by Type : Not applicable or not available Message : The TRNSYS Executable (TRNExe.exe) and main DLL (TRNDll.dll) are located in "C:\TRNSYS18demo\TRNSYS18demo\Exe"
* Notice at time : 0.000000 Generated by Unit : Not applicable or not available Generated by Type : Not applicable or not available Message : This simulation was performed with the DEMO version of TRNSYS.
* Notice at time : 0.000000 Generated by Unit : Not applicable or not available Generated by Type : Not applicable or not available TRNSYS Message 90 : TRNDll.dll is compiled in release mode. External DLLs will be loaded from the .\UserLib\ReleaseDLLs\ directory. Reported information : Not available
* Notice at time : 0.000000 Generated by Unit : Not applicable or not available Generated by Type : Not applicable or not available Message : The following Types were loaded from TRNDll64.dll: Type119
* Notice at time : 0.000000 Generated by Unit : Not applicable or not available Generated by Type : Not applicable or not available Message : "TRNSYS-BCVTB.dll" was found but did not contain any components from the input file.
* Notice at time : 0.000000 Generated by Unit : Not applicable or not available Generated by Type : Not applicable or not available TRNSYS Message 199 : TRNSYS found at least one user DLL in the UserLib directory. (Note: Only DLL's including Types that are used in the simulation are loaded) Reported information : 0 user DLLs were loaded after searching in "C:\TRNSYS18demo\TRNSYS18demo\UserLib\ReleaseDLLs"
* Fatal Error at time : 0.000000 Generated by Unit : Not applicable or not available Generated by Type : 6666 TRNSYS Message 105 : A TYPE was called in the TRNSYS input file but was either not linked into trndll.dll or was not found in an external dll. A dummy subroutine was called in its place. Please link the TYPE or remove it from the input file Reported information : Type6666 could not be located in either the TRNdll64.dll or in an external dll. Please relink theTRNDll64.dll including this Type or make sure that an external DLL in the \UserLib\DebugDLLs and \UserLib\ReleaseDLLs folders contain the Type.
* Simulation stopped with errors Total Notices : 6 Total Warnings : 0 Total Fatal Errors : 1
Also, I copied and pasted the bcvtb.dll and libexpat.dll files in TRNSYS18demo\Exe folder as it is adviced by other users but still the problem insists.
Are there any clues about what I can do to face the problem i.e. relindk the TRNDll64.dll?Is there a valid trnsys 17 version?Or maybe I could install a TRNSYS18 32bit version in my pc?
kind regards
