How can I create an schedule for energy efficiency to add in the "PhotovoltaicPerformanceSimple" using the Conversion mode scheduled depend on the temperature of the surface of painel? I want to relate the surface temperature (or at last the temperature of wheather file) to the effiency of the painel. Could be with a equation or a table of temperature x = efficiency y. It is possible? I want to compare some different tecnologies production.
Thank You.
Henrique Lauffer
