I understand that EnergyPlus is planning to use epJson as input/output file.
However, when I open EP-launch.exe in v9.0.1 which I use to run EP file usually, seems I cannot select json file as input file.
Are there any documentation which explain how I can use epjson file as input to EP-launch or CLI?
Also, are there any converter available from idf file to epjson and vice varsa?
