Hello Unmet,
I am currently writing a reporting measure script to output information from a models sql file. I ran into a specific road block when trying to use the execAndReturnVectorOfDouble method. I need to now loop through this vector and grab the data from the column %Grand Total, however whenever I try to use common vector methods like .length() or .size(), I get an error saying ":
Peak Sensible Load section failed and was skipped because: undefined method `name' for OpenStudio::OptionalDoubleVector:0x0001a263305ac8
Here Is a screenshot of my sql statement.
Any help would be greatly appreciated!
thank you
