I have one PV panel that just work at special hours according to Schedule:PV_On I modeled it in E+ according to following context. But it works all the time And produce Electricity. Here the result= link text
!- =========== ALL OBJECTS IN CLASS: SCHEDULE:COMPACT ===========
Schedule:Compact,
PV_ON, !- Name Any, !- Schedule Type Limits Name Through: 12/31, !- Field 1 For: AllDays, !- Field 2 Until: 11:00, !- Field 3 0.0, !- Field 4 Until: 15:00, !- Field 5 1.0, !- Field 6 Until: 24:00, !- Field 7 0.0; !- Field 8!- =========== ALL OBJECTS IN CLASS: GENERATOR:PVWATTS ===========
Generator:PVWatts, PV-AA, !- Name 5, !- PVWatts Version 4160, !- DC System Capacity {W} Standard, !- Module Type FixedOpenRack, !- Array Type 0.14, !- System Losses TiltAzimuth, !- Array Geometry Type 25, !- Tilt Angle {deg} 204; !- Azimuth Angle {deg}!- =========== ALL OBJECTS IN CLASS: ELECTRICLOADCENTER:INVERTER:PVWATTS ===========
ElectricLoadCenter:Inverter:PVWatts, Inverter1, !- Name 1.022, !- DC to AC Size Ratio 0.981; !- Inverter Efficiency!- =========== ALL OBJECTS IN CLASS: ELECTRICLOADCENTER:GENERATORS ===========
ElectricLoadCenter:Generators, PVList1, !- Name PV-AA, !- Generator 1 Name Generator:PVWatts, !- Generator 1 Object Type 4160, !- Generator 1 Rated Electric Power Output {W} PV_ON, !- Generator 1 Availability Schedule Name ; !- Generator 1 Rated Thermal toElectrical Power Ratio!- =========== ALL OBJECTS IN CLASS: ELECTRICLOADCENTER:DISTRIBUTION ===========
ElectricLoadCenter:Distribution, ELC1, !- Name PVList1, !- Generator List Name Baseload, !- Generator Operation Scheme Type 0, !- Generator Demand Limit Scheme Purchased Electric Demand Limit {W} , !- Generator Track Schedule Name Scheme Schedule Name , !- Generator Track Meter Scheme Meter Name DirectCurrentWithInverter, !- Electrical Buss Type Inverter1; !- Inverter Name
