Looking deeply in IO Reference and Engineering Reference, It is not clear if AirChiller Can be used in conjuntion with a Secondary System. The idea should be that the SecondarySystem (Evatorator) connects the primary Refrigeration System to a Glicol second loop that feeds into the Airchiller.
In the example file only direct connection of airchiller with system are presented while in the IOref it seems possible but the simulation do not run as expeted (even if does not report any errors)
Any other experience?
