Program Version,EnergyPlus 6.0.0.023, 19-12-2018 11:38,IDD_Version 6.0.0.023 *** Beginning Zone Sizing Calculations * Warning * SizingPeriod:DesignDay: AHMEDABAD:1.0% WINTER * ~~~ * Humidity Indicator Temperature at Max Temp=12.8 > Max DryBulb=12.2 * ~~~ * Humidity Indicating Type=WETBULB * ~~~ * Conditions for day will be set to Relative Humidity = 100% * Warning * Zone areasinside surface emissivities are summing to zero, for Zone="Z1" * ~~~ * As a result, MRT will be set to MAT for that zone *** Beginning System Sizing Calculations * Warning * Could not find chilled water coil with name SYSFANPWRVAV_SYS 1 COOLING COIL on any plant loop * ~~~ * Autosizing of water coil requires a cooling loop Sizing:Plant object * ~~~ * Occurs in water coil object= SYSFANPWRVAV_SYS 1 COOLING COIL * Fatal * Preceeding water coil sizing errors cause program termination ...Summary of Errors that led to program termination: ..... Reference severe error count=0 ..... Last severe error= *** Fatal error -- final processing. More error messages may appear. *** Testing Individual Branch Integrity * Warning * There are orphaned Branches in input *** All Branches passed integrity testing *** Testing Individual Supply Air Path Integrity *** All Supply Air Paths passed integrity testing *** Testing Individual Return Air Path Integrity *** All Return Air Paths passed integrity testing * Severe * Node Connection Error, Node="SYSFANPWRVAV_SYS 1 COOLING COIL CHW INLET", Inlet node did not find an appropriate matching "outlet" node. * ~~~ * If this is an outdoor air inlet node, it must be listed in an OutdoorAir:Node or OutdoorAir:NodeList object. * ~~~ * Reference Object=BRANCH, Name=SYSFANPWRVAV_SYS 1 COOLING COIL CHW BRANCH * Severe * Node Connection Error, Node="SYSFANPWRVAV_SYS 1 HEATING COIL HW INLET", Inlet node did not find an appropriate matching "outlet" node. * ~~~ * If this is an outdoor air inlet node, it must be listed in an OutdoorAir:Node or OutdoorAir:NodeList object. * ~~~ * Reference Object=BRANCH, Name=SYSFANPWRVAV_SYS 1 HEATING COIL HW BRANCH * Severe * Node Connection Error, Node="SYSFANPWRVAV_SYS 1 HEATING COIL HW INLET", Inlet node did not find an appropriate matching "outlet" node. * ~~~ * If this is an outdoor air inlet node, it must be listed in an OutdoorAir:Node or OutdoorAir:NodeList object. * ~~~ * Reference Object=COIL:HEATING:WATER, Name=SYSFANPWRVAV_SYS 1 HEATING COIL * Severe * Node Connection Error, Node="SYSFANPWRVAV_SYS 1 COOLING COIL CHW INLET", Inlet node did not find an appropriate matching "outlet" node. * ~~~ * If this is an outdoor air inlet node, it must be listed in an OutdoorAir:Node or OutdoorAir:NodeList object. * ~~~ * Reference Object=COIL:COOLING:WATER, Name=SYSFANPWRVAV_SYS 1 COOLING COIL **** There were 4 node connection errors noted.
*** ===== Final Error Summary ===== *** The following error categories occurred. Consider correcting or noting. *** Node Connection Errors *** ..Node connection errors are often caused by spelling mistakes in a node name field. *** ..To track down the problem, search the idf file for each node name listed to see if it *** ..occurs in the expected input fields.
*** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 2 Warning; 0 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 4 Warning; 4 Severe Errors; Elapsed Time=00hr 00min 2.42sec
