OpenStudio failure to open
I had OpenStudio working fine already six months ago. After unknowingly pitting "load library" against OS's refactoring and trying anything I could think of yesterday, I find that the program will no longer open. I have uninstalled and reinstalled multiple times--according to directions, too! I have removed a couple lines related to OpenStudio from the registry, but all to no avail. I have also tried relocating OSM files and related folders. I don't whether to call this more a Windows problem or an OpenStudio issue.
Here's some of what shows up in Event Viewer (there is more, if that will help), though I understand none of it.
Fault bucket 1958325407010196452, type 5 Event Name: AppHangB1 Response: Not available Cab Id: 0
Problem signature: P1: OpenStudioApp.exe P2: 2.7.0.0 P3: 5bc42e57 P4: 9257 P5: 67246080 P6: P7: P8: P9: P10:
Attached files: \?\C:\Users\Duane\AppData\Local\Temp\WERD358.tmp.version.xml \?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERD359.tmp.WERInternalMetadata.xml \?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERD379.tmp.xml \?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERD377.tmp.csv \?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERD397.tmp.txt \?\C:\Users\Duane\AppData\Local\Temp\WERD399.tmp.xml C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Critical_OpenStudioApp.ex_3b603812e0b5323e498266e062827531106bf4_2a7ef314_cab_3c32d3e4\triagedump.dmp C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Critical_OpenStudioApp.ex_3b603812e0b5323e498266e062827531106bf4_2a7ef314_cab_3c32d3e4\memory.hdmp
These files may be available here: C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Critical_OpenStudioApp.ex_3b603812e0b5323e498266e062827531106bf4_2a7ef314_1a22e605
Analysis symbol: Rechecking for solution: 0 Report Id: 3eaaa5ab-6b00-413d-853d-2455a0b7edc7 Report Status: 268435456 Hashed bucket: 36e44eb40ae3d717fb2d5e94ff770be4 Cab Guid: 0
Cab Id: 0
0 Problem signature: P1: OpenStudioApp.exe P2: 2.7.0.0 P3: 5bc42e57 P4: 9257 P5: 67246080 P6: P7: P8: P9: P10:
Attached files: \?\C:\Users\Duane\AppData\Local\Temp\WERD358.tmp.version.xml \?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERD359.tmp.WERInternalMetadata.xml \?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERD379.tmp.xml \?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERD377.tmp.csv \?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERD397.tmp.txt \?\C:\Users\Duane\AppData\Local\Temp\WERD399.tmp.xml \\?\C:\Users\Duane\AppData\Local\Temp\WERD358.tmp.version.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERD359.tmp.WERInternalMetadata.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERD379.tmp.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERD377.tmp.csv \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERD397.tmp.txt \\?\C:\Users\Duane\AppData\Local\Temp\WERD399.tmp.xml C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Critical_OpenStudioApp.ex_3b603812e0b5323e498266e062827531106bf4_2a7ef314_cab_3c32d3e4\triagedump.dmp C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Critical_OpenStudioApp.ex_3b603812e0b5323e498266e062827531106bf4_2a7ef314_cab_3c32d3e4\memory.hdmp
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Critical_OpenStudioApp.ex_3b603812e0b5323e498266e062827531106bf4_2a7ef314_cab_3c32d3e4\memory.hdmp These files may be available here: C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Critical_OpenStudioApp.ex_3b603812e0b5323e498266e062827531106bf4_2a7ef314_1a22e605
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Critical_OpenStudioApp.ex_3b603812e0b5323e498266e062827531106bf4_2a7ef314_1a22e605 Analysis symbol: Rechecking for solution: 0 Report Id: 3eaaa5ab-6b00-413d-853d-2455a0b7edc7 Report Status: 268435456 Hashed bucket: 36e44eb40ae3d717fb2d5e94ff770be4 Cab Guid: 0
