In reference to this post about heat dumping, how would I set up controls to supply heat to a zone only if the heating setpoint has already been met in another zone or group of zones?
| 1 | initial version |
| 2 | No.2 Revision |
In reference to this post about heat dumping, how would I set up controls a control to supply heat to a zone only if the heating setpoint has already been met temperature of a node (e.g. the supply outlet node of a plant loop) is above a set temperature?
I would like to limit the temperature of my plant loop to 80°C, and when that is exceeded to have a water convector in another a dummy zone or group of zones?start to heat a highly-ventilated space which is intended to represent outdoors.
| 3 | No.3 Revision |
In reference to this post about heat dumping, how would I set up a control to supply heat to a zone only if the temperature of a node (e.g. the supply outlet node of a plant loop) is above a set temperature?
I would like to limit the temperature of my plant loop to 80°C, and when that is exceeded to have a water convector in a dummy zone start to heat a highly-ventilated space which is intended to represent outdoors.
| 4 | No.4 Revision |
| 5 | No.5 Revision |
| 6 | retagged |
| 7 | retagged |
| 8 | retagged |
